21 years agoa problem about flash programmer
hi, all I am testing my board! my sram work well, I am testing my flash, I am using sst39vf1601-70! But when I use flash programmer to writing my flash ,nios console display: make: ...
21 years agoHi sybase2008,
What is the base address of your flash device? Is it actually located at 0020_0000? When you try to just erase the flash using the command line, do you see similar error? E.g.: $ nios2-flash-programmer --erase --base=0x00200000 --sof=my_target_board.sof Regards, --Scott
