21 years agoA problem about configuring the sys lib
Hi everyone,
Whe I try to run my design on a dev board based on NiosII(NiosII 5.0), I configured the System Library properties as: Program memory(.text) sdram Readonly data memory(.rodata) flash Read/write data memory(.rwdata) sram heap memory sdram stack memory sdram But after succeessful building,when I ran it as NiosII hardware, some err info came out on the console like this: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x002200C8: verified Downloading 00000000 ( 0%) Downloading 00200020 ( 2%) Downloading 00800000 (15%) Downloaded 56KB in 1.4s (40.0KB/s) Verifying 00000000 ( 0%) Verify failed Leaving target processor paused Could anyone give me some hints about that?And please tell me how to configure those things? By the way,I noticed when I configured them all as "sram",everything was pretty ok! So I can not figure out where the rub is... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif2 Replies
The problem is:
This means you'll have to program the flash in order to get the data there (the download/run process only works to volatile memory), and you'll have to do it anytime your statically declared data changes, as well.... NOT good for test/development! I'd advocate testing your code with rodata, in volatile memory, and then, if you need to locate it in flash, to conserve space, do it only when you're closer to release. You've also got to be aware that your performance will be less, when reading from the flash, as well. Cheers, - slackerReadonly data memory(.rodata) flash - Altera_Forum
Thank slacker! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Now I change the configuration of the sys lib properties to all "sram", and the design runs all right! But could you please give some tips in how to configure other choices of memory except (.rodata) as a volatile memory?I mean,is there some "conventional" configuration of those things? e.g what is the normal selection for heap memory and what for stack memory and the like?
