20 years agoA debug problem!
I had buid a system in SOPC Builder 5.0 with NIOS II/F, JTAG level 3, 16KBytes onchip_rom, 1KBytes exchange_ram, jtag_uart. In NIOS IDE, I compiled a sample project hello_world_simple, this pro...
20 years agoIt seems to be that you're trying to put into your RAM a block of code/data which is bigger than it's size.
Besides this, with a -C8 speed grade chip, can you run a NIOS-II at 80MHz? Doesn't your Quartus give warnings about not meeting your timing assignments? We use an EP1C12, 324pins, -C8, NIOS-II, near 89% resources usage (lots of things in hardware) and our highest speed is about 70MHz.
