20 years agoA bunch of questions ..please !
Hello All,
I'm new to Altera and uClinux.. I have a Cyclone1 dev. board.. and succeeded in installing uClinux 1.4.. but i have some questions,, please help >> 1: When i use the flash programmer with the Linux included HW .. a counter starts on the 7Segments display.. what is this ?? isnt linux free..?? 2-I want to compile MPLAYER (video player) on it .. bt before the "make" process .. i must run the "./configure" to check some system's flags.. could this be done on the NIOSII IDE ?? how ? 3- What libraries must i include in the uClinux installation to run the MPLAYER correctly ?? 4- Did any1 here managed to decode video streams using Cyclone1 ?? is it capable ?? Thanks a lot .. Yours, Tarek. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif3 Replies
>>Hello All,
>> >>I'm new to Altera and uClinux.. Welcome http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif >>I have a Cyclone1 dev. board.. and succeeded in installing uClinux 1.4.. >> >>but i have some questions,, please help >> >> >>1: When i use the flash programmer with the Linux included HW .. a counter starts on the >>7Segments display.. what is this ?? isnt linux free..?? Do not worry! That's just a counter which starts to run as an indication that the kernel runs. You can disable it in the kernel if you dislike it. >>2-I want to compile MPLAYER (video player) on it .. bt before the "make" process .. i must run the "./configure" to check some system's flags.. could this be done on the NIOSII IDE ?? how ? You'd want the toolchain build by Hippo to do serieus cross-compilation under Linux. The NiosII IDE is very limited and slow. >>3- What libraries must i include in the uClinux installation to run the MPLAYER correctly ?? I'm not sure what you like to do with mplayer, but as I use on my workstation it displays images on a framebuffer device.... I think you should start off with getting a "video-card" for the NiosII (There are frame-buffer cards available from Altera IIRC) and get a small X-server running before you even start to think about mplayer (unless you want to watch a movie over the serial console with aalib http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif ). >>4- Did any1 here managed to decode video streams using Cyclone1 ?? is it capable ?? Dunno, sorry >>Thanks a lot .. >> >>Yours, >>Tarek. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif You've got to remember that a FPGA with a NIOSII is not a workstation! Your welcome http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif - Altera_Forum
Hello again.
Millions of thanks Mr. wgoossens ok ill start figuring out what is toolchain..but i was working on windows... what are the tools needed for linux? i mean is there something like Quartus, SOPC, NIOSII IDE.. under linux? .. i really dont understand what are "video-card" for the NiosII , and "aalib".. whaat i wanted to do is trying to port the video output YUV stream to some of the FPGA's pins .. so i can interface with an external small LCD display.. at this case i will have no need for x-server ..isnt it ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif can any1 please tell me what are the AALIB and this "video-card" .. maybe it can help .. ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif thanks a lot... sorry.. im very new to this tools .. so please be patient ... Thanks in advance .. Tarek - Altera_Forum
You can find the buildroot guide here,
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) There are quartus2, nios2 IDE on Linux from Altera. But You'd better use two PCs, one for XP and the other for Linux. Use XP for quartusII/niosII to compile hardware, and use Linux for software. They can share files with samba. You can use VNC, so that you need only one screen/keyboard/mouse to control both. Most of the Linux software can be built on command line console. You can check Altera's CycloneII DSP dev board, it has the VGA and audio code. Please note that current Nios2 is MMUless. Some software may need modification to run. There is Nano-X (microwin) ported to uClinux. You should check the mplayer doc. You need some work on the video driver. Cheer!
