15 years ago60% performance loss when using µC/OS-II?
Hi all, my application doesn't work anymore after integrating it into the Webserver template. In trying to find the cause, I'm using the Altera-provided Dhrystone test. When run in a sta...
15 years agoI took a look at the Dhrystone sample and they recommend:
- 4KB I-cache - 2KB D-cache - 64KB onchip memory - program code and stack mapped to onchip memory. Even is sdram runs at cpu_clk it will never be as fast as onchip memory because it generally needs multiple cycles to access data.
