20 years ago50Mhz to 60Mhz
Dear everyone! I desig a nios2 system with EPC2C5Q208C8 ,DM9000A, running uClinux, when I test at 50Mhz, everything is OK, but when I chanhe it to 60 Mhz, the ethernet can'...
20 years agothe dm9000a only works with 25 MHz, if you cant generate this clock with a FPGA PLL tthen you must provide a 25 MHz cristal.
On the De2 board the clock for the dm9000a is derived from the 50 MHz system clock. See the de2 brd verilog file. reg ENET_CLK; always@(posedge OSC_50) ENET_CLK=~ENET_CLK;
