20 years ago50Mhz to 60Mhz
Dear everyone! I desig a nios2 system with EPC2C5Q208C8 ,DM9000A, running uClinux, when I test at 50Mhz, everything is OK, but when I chanhe it to 60 Mhz, the ethernet can'...
20 years agoyoue LE usage is quite high. It is difficult to achive high speed.
try reduce your logic, remove features which are not critical. I would try to use software to replace hardware for tasks that are not timing critical. To DSE, quartus->tools->launch Design Space Explore and check "Project use Quartus II integragted synthesis" For DM9000A, can the chip be detected and configed ?
