20 years ago50Mhz to 60Mhz
Dear everyone! I desig a nios2 system with EPC2C5Q208C8 ,DM9000A, running uClinux, when I test at 50Mhz, everything is OK, but when I chanhe it to 60 Mhz, the ethernet can'...
20 years agoHI Hippo,
Thank you very much! I have rebuild it in SOPC builder, and SDRAM is oK because the linux kernel run correctly! I use LE about 94%, and S or F core all is not OK! I have never use the DSE, I will try to use it! Could you please give me some advice about how to do? Best Regards! Fei WU
