20 years ago50Mhz to 60Mhz
Dear everyone! I desig a nios2 system with EPC2C5Q208C8 ,DM9000A, running uClinux, when I test at 50Mhz, everything is OK, but when I chanhe it to 60 Mhz, the ethernet can'...
20 years ago1. if you change the system clock, you should regenerate hardware in sopc builder.
make sure sdram and io timing are met. 2. try to reduce your logic and optimze the timing. try both S core and F core, use smaller cache size. try "design space explorer" in quartus. I have a 2C5-8 with Fmax about 76MHz.
