21 years ago
3 strange problems
1.does sl811hs support ov511+?????
2.i want to use usb web camera,should i select GRAPH/framebuffer???
3.while i tick framebuffer,there was an error"io_remap_page_range NOT defined".and there is no any define about io_remap_page_range in uclinux1.3 source code ?????
thanks!!!!
    I don't know anything about your first two questions, but the answer to the third one is to change any uses of remap_page_range to use remap_pfn_range... At least, that's the answer if uCLinux is like standard 2.6 kernels.
    Best of luck,
    - slacker
    thank slacker!!!
    i found some patch(linux2.6.9 kernel) for sl811hs and usb core and ov511 in the internet. should i add them????
