13 years ago2 Nios II with autonomous peripherals !
Hi All,
I am been using a NIOS II core in my application for performing some activites. Now i wish to add another NIOS II to do a independent activity in the same application, which i am currently doing using VHDL block. I went through the document on multiple processors from altera but it concentrates on making a shared memory application. in case of separate memories for the processors can anyone let me know how to proceed with the qsys and the software ? Regd Software i currently first JTAG the Quartus Code. Then Run the C code from Eclipse as Hardware and download it using JTAG cable. Thanks in advance. This is an urgent requirement please help.13 Replies
TO_BE_DONE
Hey.... I got the system to work. This is wat i did....
> The NIOS II Processor's Reset vector was pointing to EPCS device and Exception Vector was also Pointing to EPCS device > Program memory was pointing to SRAM > I Changed the Exception vector to an Onchip memory and now the flash programmer is working fine. Any idea why it needs to be defined like this ? - Altera_Forum
The exception vectors need to be in a RAM because they are initialized by the software just before jumping to main(). If you put them to a ROM then the initialization software can't write the correct ISR vector and the CPU would probably crash at the first raised interrupt.
I'm glad you got it to work!
