13 years ago2 Nios II with autonomous peripherals !
Hi All, I am been using a NIOS II core in my application for performing some activites. Now i wish to add another NIOS II to do a independent activity in the same application, which i am curr...
13 years agoThe exception vectors need to be in a RAM because they are initialized by the software just before jumping to main(). If you put them to a ROM then the initialization software can't write the correct ISR vector and the CPU would probably crash at the first raised interrupt.
I'm glad you got it to work!
