13 years ago2 Nios II with autonomous peripherals !
Hi All, I am been using a NIOS II core in my application for performing some activites. Now i wish to add another NIOS II to do a independent activity in the same application, which i am curr...
13 years agoThe flash programmer automatically determines the offset to the elf file, normally you should just have it burn both the FPGA image and the application at the same time, and the programmer will concatenate them. You shouldn't need to define an offset.
