20 years ago2 clocks in 1 module
Hi, My module , which is a slave , needs 2 clock inputs : system_clk (85MHz) and function_clk (27MHz) system_clk is specified when I assign signals in signal tab of component editor (avalo...
20 years agoBy the way , I'd like to ask you how I can make this module work in ModelSIM.
system_clk (85MHz) is ok but ModelSIM doesn't understand my function_clk which was specified as an export in SOPC Builder, 27MHz-expected ( it is always Z in ModelSIM) Thanks in advance, Quan
