20 years ago2-bit counter
Hi all
I need to design a 2-bit counter which output will change from 00-01-10-11 every time another counter counts up to a X value. I prefer VHDL but Verilog is fine too.3 Replies
Hi MorfiuM,
Did you consider using the lpm_counter? Regards, --Scott - Altera_Forum
Hi Scott
I checked it out but since I am a very beginner I don't know how to use the file for what I need it to do. Thanks Mick - Altera_Forum
Hi Mick,
> I don't know how to use the file for what I need it to do. Best place to get your feet wet is in the MegaWizard: 1. Double-click somewhere in you schematic file. This will open the "Symbol" dialog window. 2. In the "Libraries" explorer pane, navigate to: quartus->megafunctions->arithmetic. You'll see the extra path information, but it should be clear to you. 3. Double-click: lpm_counter. 4. Then just let the wizard guide you along ... flavor to your particular taste ;-) The end result will be a counter symbol you can place in your schematic. Regards, --Scott
