20 years ago16BIT memory
Hello there! Because of insufficient pins, i was forced to use a 16 bit SRAM memory. Now i want to run the program from this memory. i am using the cypress 32bit mem megafunction and have used ...
20 years agono, i just used doubled clock frequency for the memory. i have no exp creating a custom component. i will try it now and let u know. thank u!
The NIOS IDE says that byteblaster II is not supported and may cause communications problems. Could this be the problem, because i see opcode fetches happening in the Disassembly window...
