20 years ago16-bit flash WR/Erase problems
I have a board where the flash, ethernet and SDRAM all share a common databus. The flash device is the AM29LV128 in word mode, i.e. 16-bit interface. On power-up, linux boots fine from the flash ch...
20 years ago> Exception address points to flash. D'oh!
That's the likely culprit! Once an interrupt fires, the CPU tries to execute the current value in the flash status register. Man, I hate it when that happens! ;-) Let us know how you make out. Best Regards, --Scott
