20 years ago16-bit flash as code storage
hello we are want to use internal flash of EPC4 as code storage for nios. this is 16 bit memory. so what is the proper connection for address line and settings in SOPC builder. nios flash...
20 years ago --- Quote Start --- originally posted by m_fox@Feb 21 2006, 10:33 AM sure. problem in nios. there is no any detiled information on memory acces, like waveforms and sopc settings, that displays access to memory differ than 32 bit. --- Quote End --- Detailed information about that is included in the Avalon Interface Specification: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) --- Quote Start --- originally posted by m_fox@Feb 21 2006, 10:33 AM btw: do you know quartus progremmer program the flash?
does it erase whole flash or just page 0?
and where is information about how flash memory used?
which areas free to use by external apications? --- Quote End --- I'm sorry my knowledge is based on the Nios II I only worked with Nios (I) for some weeks. Regards, niosIIuser
