19 years ago16 bit extrenal SRAM
Dear all, I have made an NIOS 2 processor which has access to an 16b SRAM. The SOPC tri-state bridge address (total width = 19) [A18 downto A1] is connected to the SRAM address (total width...
19 years agoHi,
Are you using the stock SRAM component, provided by Altera? It will only work with the flavor of SRAMs found on Nios Dev. Kits.... i.e.: 32 bits wide If you've already designed your own custom SRAM interface, then ignore this post. If not, then you need to either create yourself a component using the component editor (builder??) or modify the existing component to suite your needs. I would recommend the latter, but it depends on your comfort level with editing the class.ptf file... Cheers, and Good luck, whatever you decide. - slacker
