12 years ago128 bits wide numbe
Hello every body; I know that an 8 bits number defined as alt_u8, How can I define a 128 bits wide number, as I use in in my code. Thanks
12 years agoIf this is for a homework problem, your professor probably wants you to use whatever language feature they most recently covered. e.g. struct or typedef.
If this is not for a homework problem, I suggest you start with this wiki page and read around and try to find the one that is going to be the best fit for you. http://en.wikipedia.org/wiki/arbitrary-precision_arithmetic
