21 years ago1 flash programming question :)
i use altera cyclone board,the flash's capacity is 8M¡£my uclinux kernel is about 2099k, filesystem is about 1987k. while i download the kernel, filesystem is covered. error:K...
21 years agothe information:
uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 007F0000 Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14384k/16384k RAM, 0k/0k ROM (1480k kernel code, 327k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 NIOS serial driver version 0.0 ttyS0 (irq = 4) is a builtin NIOS UART Serial: JTAG UART driver $Revision: 1.3 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:00:00:00 smc_probe: 50000 Khz Nios Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx CF: ctl=1 hda: Hitachi CV 7.1.1, CFA DISK drive Using anticipatory io scheduler ide0 at 0x80900800-0x80900807,0x80900838 on irq 8 hda: max request size: 128KiB hda: 31488 sectors (16 MB) w/1KiB Cache, CHS=246/4/32 hda:<6>check_part[0]=17230780: hda1 res=1:<4>CFI: Found no Microtronix map device at location zero JEDEC: Found no Microtronix map device at location zero NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 NET: Registered protocol family 17 VFS: Cannot open root device "mtdblock0" or unknown-block(0,0) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ---------then stop,7-seg led is 88.
