20 years ago1.4 with 5.1
Can we use Linux1.4 with Nios 2 IDE 5.1
Actually, while downmloading the .sof of the linux_1c20 project on FPGA after programming is 100% complete it gives error message : Can't communicate with device. and loads the FPGA with factory image. I have tried to download same using Quartus II 5.0 and 5.1 programmer but the error persists. I am able to download all other .sof other than this one. Though Nios2 is time limited opencore I am not closing the message window that appears after downloading.Even after flashing the error message the window remains. What must be the problem?2 Replies
Hello!
I use the Nios II Linux Distribution 1.4.0 and Nios II IDE Version 5.1. I have a Stratix II development board. For the kernel I use \altera\kits\nios2\examples\verilog\niosII_stratixII_2s60_ES\standard\std_2s60ES.ptf With this combination I have no problems. What board do you use? Bye, Lothar. - Altera_Forum
This issue is resolved.
5.1 patch for Quartus II and Nios II were required. Microtrinix Linux Distribution 1.4 is giving problem - After installing the Microtronics option is not appearing in Nios II IDE-> New Projects Regards
