.sopcinfo file update in imported projects
We may face such issue when we try import the project in different work-space than quartus project directory.
To avoid warning or error ".sopcinfo file is missing"
- Recreate the eclipse project with sopcinfo file or
- Import the eclipse project and edit the make file (variable name SOPC_FILE=<DIRECTORY>) and settings.bsp file (Tag name SocpDesignFile=<DIRECTORY>) such that we pointing correct directory of socpinfo file.
Which compile/build the project without error/warning.
For existing projects make sure make & settings.bsp files point to correct sopcinfo file.
import the project and build it.
Steps to import the eclipse project
Import-> Nios II Software Build Tools Project ---> Import Nios II Software Build Tools Project
Start NIOS and select work-space to 'software' folder
Import project code. Select folder for this, and make sure name of project matches folder.
Import BSP files. Select folder for this and again make sure name matches folder.
or
Zip the software folder and import.
Import->general->existing project into work-space->next->select archive file->finish.
Anand
