21 years ago.rwdata
According to last version of the SW user manual, alt_load() must be called to copy .rwdata sections to RAM. (when there is no bootloader in teh system) Where can I find info about alt_load() M...
21 years agoThe difficulty may be getting the exceptions to work for both the boot code (in on-chip memory) and subsequently getting the nios2 to vector to the program handler in SDRAM?
The exception setting appears to be set within the NIOS FPGA build, and is bound to a particular section(address) I guess I can locate the exception handler part of the boot ROM actually in a small block RAM, and part of my boot copier will load the applications handler on-top of the boot-RAM one (which is initialised via initial FPGA bitstream) ? However - this presents a problem upon nios_reset since the original exception handler for the boot RAM will now be lost (overwriting by the boot-copier) Thanks for your efforts anyway!
