19 years ago<symbol is not available> Nios II IDE 6.1
I am using the nios ide version 6.1. I have a workspace that supports two projects. One is a managed build and all is ok. The other is unmanaged, I supply the makefile. When I attempt to d...
12 years agohave your problem solved?I have the same problem with you!it makes meetrouble.
