12 years ago.jic file procedure for EPCQ256
I saw a previous post commenting that the NIOS flash programmer will not work for the EPCQ devices. Given that, what is the procedure creating a .jic file that I can blow into the EPCQ256 for Active...
12 years agoThe FPGA is Arria V series. The configuration device is an EPCQ. However, the flash controllers only seem to communicate in EPCS/EPCQx1 mode in any of the Nios cores.
Nominally, I shouldn't *need* the .jic file. I should be able to use the flash programmer to write the EPCQ device. Unfortunately, that doesn't seem to work either.
