12 years ago.hex file generate for Nios-II C code
Hi, I am using Quartus-II Version 9.1sp2 and i am also using Nios-II IDE Version 9.1. I have a Custom board with Cyclone-I FPGA EP1C12Q240C8N. I made Nios-II Base project using SOPC Builder...
12 years agoHi,
try to append "--record=4" after "elf2hex STQFP.elf 0x00004000 0x00007fff --width=32" before the backslash (in your projects mem_init.mk file). I have to do this for years, now. I don't know how other people get a working hex file out of the automatic Nios II build process. Once i regenerate my BSP, I have to add this line, again, because it overwrites the mem_init.mk file. I'm not a "build process"- / make- /toolchain- /whatever-guru, so I was not able to find an automatic solution for this issue. I just take it as a little drawback of the tools which I found my own workaround for. Please report, if it also solved you problem. Regards, Maik
