21 years ago.entry section and reset address
Hi, I'm using eCos for Nios-II 1.1 on a custom board. The reset address is in the epcs controller boot ROM. The eCos startup type is set to ROMRAM. The elf .entry section appears t...
21 years agoWhen using Nios II download from Nios II 1.1 it shouldn't matter that you have this extra section. It will try and write the .entry section to the boot address (i.e. the location of the EPCS) and ignore the fact it can't. However if you have upgraded to Nios II 5.0, then you will start to see problems. If this is the case then you should also upgrade eCos to the Nios II 5.0 version. This updated version will not generate the .entry section for a ROMRAM configuration.
