12 years ago.elf file explained?
Hello! I have just watched the ALTERA Embedded Design Flow video tutorial and at some point at the end it is explained how the user can program a flash memory with: - A boot loader - The...
12 years agoWhen I tried to build my own epcs 'controller', I failed to get the io pins marked as 'dual purpose' - all greyed out.
There might be a 380 byte bootloader, but look at the size of the HAL functions for later access. In any case the bootloader has an entire memory block to play with - so it doesn't matter much provided it fits.
