12 years ago.elf file explained?
Hello! I have just watched the ALTERA Embedded Design Flow video tutorial and at some point at the end it is explained how the user can program a flash memory with: - A boot loader - The...
12 years agoUnderstood. But the bootloader is run by Nios and Nios needs to access the EPCS through the Qsys interface. In order for that to happen don't I need to export the EPCS interface wires to some pins? Or you sa that this gets done automatically without exporting the pins to the top level entity?
