12 years ago.elf file explained?
Hello! I have just watched the ALTERA Embedded Design Flow video tutorial and at some point at the end it is explained how the user can program a flash memory with: - A boot loader - The...
12 years agoAfter initial FPGA configuration, the EPCS can be accessed through the EPCS serial flash controller.
The Qsys ECPS serial flash controller will also contain the bootloader code required to copy the data from the flash to the SDRAM.
