21 years ago###### Code Size in IDE NIOS II ######
Hi Guys and Gurus, I am back with another intriguing problem. I am using NIOSII for DSP work. Now, I am realizing that a. if the elf code size goes past 32KB, so that only 218 KB is left for...
21 years agoA long time ago I looked at adding the floating point hardware available in Quartus (called LPM_FP or something similar). Then you could attach it as a custom instruction. That is another solution to look at (but I would try mpaolini's FP logic first since it's less work to reuse than design).
