21 years ago###### Code Size in IDE NIOS II ######
Hi Guys and Gurus, I am back with another intriguing problem. I am using NIOSII for DSP work. Now, I am realizing that a. if the elf code size goes past 32KB, so that only 218 KB is left for...
21 years agoGESP,
One of our Altera embedded specialists created a suite of floating point custom instructions with supporting C libraries that are available for download from this forum. Look in the "Post your own IP" area. His nickname is "mpaolini" -- you may have to go a page or two back. He has done both single & double precision versions. Alternatively, another one of our partners in Australia made several floating point custom instructions. These are also in the post-your-IP area.
