20 years ago? cfi-flash
When trying to use the NIOS IDE Flash Programmer on a custom board at USER, I get the message:
CFI- no flashtable at address 0x00000000 Programming aborts, There is only a CFI flash on this board, no EPCS The reset vector is pointing to ext-flash: 0x00000000 The configuration controller is set to operate on: USER 0xC0000000 Recovery 0xE0000000 As the instruction says: the flash base is to be 0x00000000 I put three flash sections in the SOPC: Hardware_FPGA 0x00000000 USER 0xC0000000 Recovery 0xE0000000 Is there a communication between the NIOS Programmer and the config controller? Or do I have to change my reset vector? What do I have to change? Thanks in advance. andyNo RepliesBe the first to reply
