如何约束altera_reserved_tck以及JTAG的相关信号管脚
- 4 years ago
I would suggest you set a 10MHz constraint to the altera_reserved_tck pin to constrain this JTAG clock.
The altera_reserved_tck pin is automatically generated for a design that uses a JTAG accessible module such as the SignalTap logic analyzer or the NIOS II debugger.
Thank you.
您好,
我建议的方案就是您试试把altera_reserved_tck管脚约束设置为10MHz。
这是因为SignalTap Analyzer或NIOS II debugger 引用了JTAG组件, 会自动化地引起altera_reserved_tck管脚.
谢谢
Kelly
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey. Thank you.
很高兴可以为您服务。如果您满意于我们的答复和服务,亲您在调查表里给个高评价9/10分。
谢谢您。
Kelly Jialin, GOH
