china_cn
4 years ago如何约束altera_reserved_tck以及JTAG的相关信号管脚
我正在使用 Intel-ARRIA 10-GX FPGA Development Kit进行开发。在我一个工程中使用了nios来调用SPI,并且在顶层模块中例化了4个jesd204b的ip核。signaltap中抓取了部分jesd204b的输出信号。
但是在下载nios程序的过程中发现nios下载出错,提示的信息是:
verify failed between address 0x0 a...
- 4 years ago
I would suggest you set a 10MHz constraint to the altera_reserved_tck pin to constrain this JTAG clock.
The altera_reserved_tck pin is automatically generated for a design that uses a JTAG accessible module such as the SignalTap logic analyzer or the NIOS II debugger.
Thank you.
您好,
我建议的方案就是您试试把altera_reserved_tck管脚约束设置为10MHz。
这是因为SignalTap Analyzer或NIOS II debugger 引用了JTAG组件, 会自动化地引起altera_reserved_tck管脚.
谢谢
Kelly
KellyJialin_Goh
4 years agoHi,
Is the information provided useful?
Kelly
