DZhu1
6 years ago如何在quartus pro19.1上安装nios eds
安装完quartus19.1以后,无法打开nios eds。pro19.0以前的版本都可以正常打开的。这个问题该如何解决?谢谢
Ahmed_H_Intel1
6 years agoHi,
The Eclipse now needs to be installed separately after installing the Quartus. The following link tells you how to install the NIOS II SBT.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
Cliver1
5 years agoHi this link no longer works - file not found!
