14 years ago‘Nios II Application and BSP from Template’ not available
Hello, I am new in this forum; I have checked but apparently nobody had a problem similar to mine: I installed the Quartus Web Edition, which includes NIOS II 11.1sp2 Software Build Tools fo...
14 years ago --- Quote Start --- Hi, Maybe you'll get some hints, when you open your NIOS EDS from the cmd in Windows, maybe even with a verbose option or something. --- Quote End --- OK, I tracked down the eclipse-nios2.exe file, and ran it from a windows command shell - it just launches it and then get a new prompt in the shell, while the program keeps running. Not sure about a verbose option .... seems to ignore all flags.
