16 years agoµclinux ,problem of script checkout
hello, i would download linux distrubution for NIOS II procesor i followed the steps in nioswiki : for new users who didn't used nios2 git before, please download the tarball (1.7GB) ,as a n...
16 years agoThis is the error :
nios2-linux-gnu-gcc: command not found; perhaps you need to fix your PATH? Did you followed the guide step by step at http://www.nioswiki.com/linux ? In the Quick start page, the first thing you have to do is to set up the path to the toolchain : PATH=$PATH:~/nios2-linux/toolchain-mmu/x86-linux2/bin If you don't want to add it to your .bash_profile ok but then you have to set up the path in a terminal, bash. This command is useful to find program for the cross-compilation.
