20 years agoµCLinux in Stratix GX Development Board
Hi, I am wondering if it is possible to implement a µCLinux in a Stratix GX Development Board? In fact, I have a Stratix GX Development Board in order to develop high speed applications. D...
20 years ago --- Quote Start --- originally posted by freechip@May 19 2006, 04:49 AM macio,
i have found an answer to your problem. (ddr controller error with stratix gx device).
http://www.altera.com/support/kdb/solution...022005_688.html (http://www.altera.com/support/kdb/solutions/rd12022005_688.html)
freechip
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15462)
--- quote end ---
--- Quote End --- Thanks a lot Freechip. It was solution of my problem. Unfortunately I have now compilation errors in Quartus, but I will try to solve this problem. As I wrote I have 256MB DDR SDRAM on my board. Nios can address only 256MB but you can change number of column address bits in DDR SDRAM Controller Megacore IP Toolbench from 10 bits to 9 bits. In that way only half of that memory will be used but you can add other peripherals to system and you won't have error "Address range of instruction master crosses 256-Mbyte".
