20 years agoµCLinux in Stratix GX Development Board
Hi, I am wondering if it is possible to implement a µCLinux in a Stratix GX Development Board? In fact, I have a Stratix GX Development Board in order to develop high speed applications. D...
20 years ago --- Quote Start --- originally posted by freechip@May 16 2006, 04:40 PM ok, thanks but i will have a version problem if i want to use stratix gx.
why? because the microtronix nios ii linux distribution (v1.4) has been updated to support the nios ii 5.0 ide and quartus 5.0.
the problem is that the family device stratix gx in the sobcbuilder 5.0 is not supported. so i have to use the quartus 5.1 and nios ii 5.1, both are not supported by the microtronix nios ii linux distribution (v1.4).
i hope you understand my problem.
if you have a solution...
(i think to use ecos if it is impossible for me to do that with uclinux.
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15397)
--- quote end ---
--- Quote End --- We know there are a lot of problems with Microtronix Nios II Linux Distribution (v1.4) on IDE. That's why I suggest you follow the buildroot guide. It is a different approach, which can be used with all Quartus II and Nios II version. It is very easy to use and customize. Many people on the forum have successed by following the buildroot guide.
