MEmel1
7 years agoWhy there's no clock on afi_clk output of the Hard DDR3 Memory Controller, although clock on pll_ref_clk input is present?
I've a problem running DDR3 HMC on Cyclone V SoC Development Board. I instantiated HMC megafunction in schematic top level file, made mem_ pin assignments, connected pll_ref_clk pin to CLK_BOT1 board...
sstrell
7 years agoWhat is your indication that afi_clk is not running?
You can get any interface out of a Platform Designer system by adding in a bridge component and exporting the extra interface. You'd use a clock bridge component for this, but since you are using the hardened interface, I don't know if it's possible to connect that back to soft FPGA logic.
Are you seeing the user clock coming from the IP?
