MEmel1
7 years agoWhy there's no clock on afi_clk output of the Hard DDR3 Memory Controller, although clock on pll_ref_clk input is present?
I've a problem running DDR3 HMC on Cyclone V SoC Development Board. I instantiated HMC megafunction in schematic top level file, made mem_ pin assignments, connected pll_ref_clk pin to CLK_BOT1 board...
MEmel1
7 years agoThanks for the reply, NAli1,
I actually did that. Basically I set the same settings in my megafunction as in fpga_sdram Qsys component of the reference design. The differences are only in chip/board timing constrains, in physical chip interface width (reference design uses two DDR3 chips as opposed to mine which uses one), and in Avalone MM interface width. But I can't see how are these differences relevant to the complete absence of UniPHY generated clock (afi_clk). The clock settings are the same as are the pin assignments.
I was going to check the same afi_clk clock in reference design, but run into another trouble using Qsys: i can't export component pin which is also used internally. It's avaliable ether for internal use, or for export.
