9 years agoWhy the tx_serial_data is single ended in 10G BASE R IP
hi, why the tx_serial_data/rx_serial_data of 10G base-R is single ended? Will the quartus insert one diff buf for it if I only use this the single ended tx_serial_data/rx_serial_data a...
9 years agoHi,
yes, when you assign tx_serial_data/rx_serial_data pin locations and LVDS standart it will automaticaly create differential pairs for tx_serial_data/rx_serial_data pins.
