LZhao1
6 years agoWhy NCO IP outputs ZERO?
when customer use a NCO IP on Arri10 SX, in Quartus Prime 19.2pro, found that output SIN and COS both are ZERO
KhaiChein_Y_Intel
6 years agoHi,
Could you provide more details? Can you provide a test case and result for investigation?
LZhao1
6 years agoHi,
We found that in Quartus 19.2pro, some .hex files generated by NCO IP has a mismatch location where system needs, so we manually move those .hex files to correct location, then, NCO IP can function right.
Maybe in Quartus 19.4pro can fix the problem, I have not verify yet.
