BarryT's avatar
BarryT
3 years ago
Why does the E-Tile transceiver PHY IP get zero eye height in some cases?
We have tested many devices and only a few environments where the Eye Height value is 0 for 2.5G read and the data is normally sent and received. This causes a lot of problems.
So, I would like to ask what causes this phenomenon. Is there any solution?
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Hi BarryT,
    May I know that your TTK using which Quartus version?
    Zi Ying
  • BarryT's avatar
    BarryT
    Hi Zi Ying,
    it's Quartus Prime Version 20.1.0.
    But we don't use TTK to get the eye height, we use attribute code to get it.
    BarryT
    ZiYing_Intel
    Hi BarryT,
    Can you try to use TTK to see eye viewer still got 0 height?
    Zi Ying
    ZiYing_Intel
    Hi BarryT,
    Is there any update from your side?
    Zi Ying
    • BarryT's avatar
      BarryT
      Hi Zi Ying,
      I do not have the conditions to use TTK to get eye height, maybe I need to think about other ways.
      Thanks for your help.
      BarryT
