14 years agowho can help me about PCI compiler
I developed a SOPC which including a PCI compiler on the ALtera PCI development kit, the configuration of PCI compiler was: Host Bridge Mode, 32bit, 33MHz, BAR0 Auto, BAR1 auto, two fixed address tra...
14 years agoOne additional thing you might need is an arbiter to grant the master access to the bus when it requests it.
Or in your master design just hard wire the grant signal active. ? Nial
