14 years agowho can help me about PCI compiler
I developed a SOPC which including a PCI compiler on the ALtera PCI development kit, the configuration of PCI compiler was: Host Bridge Mode, 32bit, 33MHz, BAR0 Auto, BAR1 auto, two fixed address tra...
14 years ago --- Quote Start --- There is no os. --- Quote End --- Ok. --- Quote Start --- I just want to use the board with pci compiler as pci master, and another board connected to it as slave. Under Nios II IDE, how can i access the configuration space of master device or slave device? --- Quote End --- Is the PCI core an Avalon component? If it is, then in your SOPC or Qsys System, there should be an Avalon-MM slave block for the configuration space, another for PCI accesses, and there may be some other registers so that the PCI accesses will use I/O or memory commands. If the PCI core is not an Avalon component, then the same sorts of register interfaces will likely exist, its just that you'll have to create Avalon-MM interfaces, so that your SOPC system containing the NIOS core can access those registers. I would recommend starting with a testbench of just the PCI core alone, and figure out how to get a couple of instances talking to each other, i.e., configure one as the master and one as the target. Cheers, Dave
