14 years agowho can help me about PCI compiler
I developed a SOPC which including a PCI compiler on the ALtera PCI development kit, the configuration of PCI compiler was: Host Bridge Mode, 32bit, 33MHz, BAR0 Auto, BAR1 auto, two fixed address tra...
14 years ago --- Quote Start --- I developed a SOPC which including a PCI compiler on the ALtera PCI development kit, the configuration of PCI compiler was: Host Bridge Mode, 32bit, 33MHz, BAR0 Auto, BAR1 auto, two fixed address translation table including a configuration space and a memory space. my question is : how can i access the configuration space to read regs sucn as Device ID or Vendor ID ? --- Quote End --- Under what operating system? Under Linux you simply type lspci (and then man lspci to learn more). Under Windows, there is a tool called pcitree (and others). PCI device drivers under Linux are pretty simple. If that is what you are interested in, then I'll post some links. Cheers, Dave
