Which FPGA IP can be used FREE in production with the Quartus LITE dev. sw?
- 2 years ago
I tested a bit in Quartus Prime Light (20.1.1) for a MAX10 (10M50DA type), and these are some findings.
- It seems it's the more elaborate IPs that needs paid licenses (as has been said), so PLLs, use of ADC in MAX10, etc. are free
- You can disable use og Evaluation licenses:
Assignments > Settings > Compilation Process Settings > More Settings > Intel FPGA IP Evaluation Mode: Disable
- In the Compilation Report you can check (examples when disabled):
- Assembler > Encrypted IP Cores Summary (Gives for example: Nios II Embedded...: Unlicensed; Signal Tap: Licensed)
- Assembler > Messages (gives for example)
- 115003 Can't generate programming files ... not valid license for following IP core(s)
115005 Unlicensed IP: "Nios II Embedded Processor Encrypted output..."
115004 Unlicensed encrypted design file: "c:/....../altera_nios_gen2_rtl_module.sv"- When Evaluation mode is Enabled, you get the programming file <name>_time_limited.sof (as Frank said earlier).
- You can also check in the Compilation Report
- Analysis & Synthesis > IP Cores Summary, the Licence Type column
For example: Signal Tap: Licensed; no licence needed (it seems): N/A, Nios II Embedded...: OpenCore (not free)(Nios II is btw outdated, Nios V should be used for new designs, but it needs a paid license as well.)
So, I'm a bit more optimistic, seems that much of the simpler IP in Platform Designer in Quartus can be used.
IP that needs a payed license is e.g. CIC Filter, FFT, NCO, Ethernet MAC. It shows by generating only time-limited .sof in Quartus lite and no other programming files.
Frank
Yeah, but you've got to go through actually creating and generating the IP to find that out.
- SmallBusinessOwner2 years ago
Thanks Frank. Then you get a warning, at least. And at the end of the process, as sstrell say... I guess it might be asking too much to get that information earlier, e.g. before you start investing time in the IP... So, do a mock generation to root out if it's an expesive dude you're dealing with?
